Road Cycling Essentials
Status
Not open for further replies.
I went for the standard double because I prefer the smoother transition at the front. So far I've been okay with 39-27 as my lowest gear but I am worried about the day I find something too steep for that gear and have to bail!
I need to start exploring Surrey for harder hills than Box Hill.
I've got a compact and a 30 at the back as well. :o
I find i need the lower couple of gears less and less these days (only had the road bike 9 months) but it's handy that it's there. Occasionally i'll hit something that ramps up to around 20% and i definitely need it then!
Also, I'm definitely someone that likes to try and keep spinning as i go uphill. I don't have the strength in my legs to grind up hills in a big gear, not without knackering myself way too early in a longer ride. So anything that helps me keep my cadence up on the hills works for me.
http://www.jibbering.com/hills/
The trick is to find a route that covers as may as possible without crossing the same route twice.
Where do you get that threshold number from?
I'm a bit skeptical of a lot of HR training. Using my HR monitor vs trainer road on my turbo to give power output I've noticed various factors that can affect heart rate, especially around conditioning.
As an example, tonight my HR was nearly 10BPM higher than normal when I did a 20min FTP test. I was absolutely flat out, and my HR stayed over 200BPM for the last 15mins of the test, hitting 208. I've never managed over 205BPM in the past, even doing some extreme intervals. This gave me a LTHR of 191BPM
Other times when I've been in better condition I've ridden at a v similar effort, but at least 10BPM lower, giving me a LTHR of around 181
I don't think this is a case of a dodgy heart rate monitor either, the numbers are consistent but seem to shift based upon various factors. The other thing is, pretty much whatever range of numbers I come out with, my 'zones' seem v compressed in reality towards the higher end, so if I were to use the lower zones, I honestly can't see how it would be any benefit to me training wise as I'd never get close to a seriously intense workout!
first 10 mins of a 30 min ride with no heart rate monitor on, then the last 20 mins i switch it on, and have to take the average
thats 30 mins of the hardest i can push and sustain for that length of time
The problem I've got is it takes me 20 miles to get out into Surrey from Clapham so until I start making 50-60mi rides my "norm" I'll probably bonk trying to do a hilly route followed by the return journey.:(
Thanks for that link though! :)
[Damien];23790086 said:
Come up north, we've got plenty!
I plan to take my bike up and visit a mate who lives in Macclesfield at some point. He has lots of nice climbs including the Cat & Fiddle!
Having to report here as I post in the 'Big Bike' thread, thinking it's a big thread about bike, rather than it being a MTB thread :p
My work's Cycle to Work Scheme is back! YAY!
Here's my situation, used to commute to work on a hybrid Raleigh, cycled rain, sun and snow on a 6mile return journey (nearly completely flat, Hull).
Since the bike got knicked last year, I've been eyeing on a road bike as I've moved to Pontefract, nice Yorkshire hilly roads for cycling!
What should I look out for for looking to get a road bike? My cycle to work scheme allows me to go up to £1000 inc accessories BUT I want to work on a budget of £500-£600 bike only.
Any suggestions? Where I live, there's an Evans cycle shop - been looking around and these stands out...
1) Fuji Sportif 1.5 Compact 2013 £600
2) Specialized Allez Compact 2013 £550
3) Pinnacle Dolomite 2 2013 £550 (+ free £100 worth of accessories)
4) Pinnacle Dolomite 1 2013 £450 (+ free £50 worth of accessories)
Does Carbon fork REALLY make a difference? Bearing in mind, this is me coming from a heavy-ish hybrid with MTB tyres. I am looking for a bike to go fast. Commute on weekdays, go enjoy the roads on weekends.
Additional info if it makes a difference; I'm 174cm.
Hmm, I think you're always going to have some issues outside as unless it's 30mins of climbing and no junctions, any freewheeling will begin to skew things, so it's probably a few BPM low
Short answer; a carbon fork SHOULD make a considerable difference to comfort over an aluminium fork.
Long answer and other advice will have to wait until I've got to my hotel.
If you're looking to do some structured training I'd flog your rollers (I remember you saying you weren't getting on with them?) and pick up a turbo and the kit to run TrainerRoad at home. Training off heart rate is always going to be a bit hit and miss.
that is true
the road i used is rather good, 5-6 miles without any hassle, trouble is, i got to the end and had to turn round lol
did my training ride again today, this time (as i said last night) had to use Zone 3 and those figues i quoted did seem pretty good, was in Z3 when i needed to be, and down to Zone 1/2 between efforts
i havent tried the rollers in ages, im waiting for the warmer weather, then im going to try them again, ive only had a couple of goes, but the thing is, where its situated im not holding on at the height i need, so when i let go the bike goes off the end! lol
i need to look at it again and give it another go
Looking forward to it :)
I keep forgetting to update with my TR/sufferfest progress, but after yesterday's FTP test, my power output has increased 41W since Christmas! I've been using the same tyre pressure/resistance setting on my kurt kinetic so it's not just a setup problem issue! :)
Looking at signing up to more sportives now before the dragon ride, plus a possible Tenerife trip :)
The problem I have is getting to anywhere interesting in a limited time in the evenings after work. I can't get out till after seven, and at the moment it's cold and dark, so I can only get so far. I can make it to a cat 4 in reasonable time but can't go exploring much beyond that, so then it's a case of trying to string together a few smaller hills on the way back.
Roll on Saturday morning and a longer ride in the daylight...
Awesome. :D After my crap first test result my first target is increasing my FTP to 200W (from 141W) which would put me at around 3w/kg. My ultimate target is 4w/kg but I'd be happy to hit 250W by the end of this year. Did my first session this morning in Base I (Gayley) and found it pretty comfortable so potentially my FTP is set a little low. I'm going to do the first four weeks and reassess then.
Status
