Don
- 20 Oct 2002
- Oxfordshire / Bucks
how are you measuring your power ?
http://www.trainerroad.com/
Standard disclaimer is the power outputs measured are not necessarily comparable with someone else's, but they are excellent as a way of tracking your own fitness. Having said that, anecdotal evidence says the numbers are fairly accurate.
cheers
is that accurate?
i was thinking more for away from home use, i guess the only way is a power crank? (or what ever they are called)
Just been looking at lights for the past few hours
what whould you recomend, for not specific "night" riding, but in condiitions where it not quite bright in the mornings and starting to get a little dark
i am thinking flashing front and rear with a cheap constant light on the front
Speaking of which, my first 100 mile ride is go for the weekend and I've roped in my regular cycling buddy.
http://www.ebay.co.uk/itm/1200-Lume...isure_Cycling_Bike_Lights&hash=item4601c5b6ce
and
http://planet-x-bikes.co.uk/i/q/LIPHBPDRL/phaart_bleep_dual_05_watt_led_rear_light
The top item will take a while to arrive. There are UK sellers who will cut down your shipping time but obviously they are more expensive. The light has 3 modes which will cover you from a low "be seen" light to a light bright enough for unlit lanes.
The bottom item is an RSP Astrum clone and for £2.50 is ridiculous value. They tend to leak eventually but a bit of vaseline round the seals usually prevents that and, hey, they are £2.50.
This debate always comes up but, from a driver's point of view, don't use flashing lights. They are distracting but not in a good way and make it harder to judge how far away you are and how fast you're going.
cheers
is that accurate?
[Damien];23793203 said:What route are you going on? I'm doing this one (tcx link, use bikeroutetoaster to view). I don't really know Cheshire but I've got a mate from Knutsford so he's coming along for that section.
Cheshire is really nice for riding, I usually go out round there or the Peaks depending on how fit I'm feeling.
Got a(nother) flat this morning!! 2nd time in a week after not having one at all since I got the bike last August![]()
[Damien];23795311 said:What tyres do you have?
these are the two front lights ive got my eye on
more than i want to pay really, but they are very bright as far as i can tell, also they dont have an external battery pack which is a bonus
if im going go spend say £30+ on a front light, I may as well get the best for not much more
http://road.cc/content/review/72271-lezyne-macro-drive-front-light
http://road.cc/content/review/71583-moon-meteor-front-light
Giant PR3's that came with the bike. Thought about changing them for GP4000s at one point but then never got around to it and had other things I needed to buy!
Never had a problem up until this last week or so.
Last one was a pinch flat, and I'm thinking this is probably the same. Haven't been able to tell what pressure my tyres were at this week because my presta pump adapter is screwed, so I've been using my hand pump :/ Waiting on a new one, which should be here today or tomorrow!
