Road Cycling Essentials
Status
Not open for further replies.
[Damien];23796376 said:
From the looks of it you just need whatever tools to remove your existing BB and then the hollowtech BB cups you'll get as part of the groupset will screw into the existing threads. So apart from that tool I linked you just need either the tools to remove your existing BB (this and this according to a quick look on google) or just get the LBS to remove the old BB for you and then do the rest at home.
You'd be better off getting a kit that has all the tools you need. I have a similar kit and it's really handy.
Ive got all my bits ready to go now for Trainer Road, before i sign up tho, i was wondering can i run the program, then put my 3LC Road Race DVD in, do that and then see my results at the end of it? i see you can watch a movie on their website but it looks like your following their plan there
I'm not an expert by any means, but I know the Sufferfest videos have been integrated into Trainer Road so that the target watts on the screen reflect what is happening in the video. It's possible that someone has created a ride for the 3LC videos too but I'm not able to check at work.
That's a tidy kit. I'd pick one up if I didn't have individual versions of most of that kicking about the house somewhere already.
Speaking of having a crapload of tools, I took apart my crank/BB again last night. I've got BB30 bearings and every so often (every couple of months or so) I'll get a creaking when putting power into the pedals. The first time it happened I eventually narrowed it down to the bearing/frame surfaces rubbing together as the frame flexes. When it happens I take the crank apart (a ballache), pop out the bearings (with another set of bloody tools), regrease the outside of them and the inside of the frame and stick them back in and reassemble. After this it's all quiet again.
Does anyone else with BB30 bearings have this problem or do I just make the frame flex more than most? I can reproduce the creak when it happens by standing next to the bike and pushing down on one pedal (to flex the frame sideways) when it's at 6 o'clock. I can then spin the crank and do the same from the other side.
ill snap some pics of the front/rear for you today - ill be riding home and there's a road thats closed off.. so i go through the park at night and its pitch black :o
45lumens is nothing for a front light :) even my 2x200 are not THAT bright but more than enough for anything tbh.. i think damien has the same set.
from the same shop
what this ike compared to yours
its £12.99 , not sure how it compares to the UltraFire though
http://www.ebay.co.uk/itm/Cree-XM-L...isure_Cycling_Bike_Lights&hash=item416e930970
its a single instead of two, i dont really want two on the front
I replaced the brakepads with Swissstop Greens - so new brakepads + brakeshoes. Was about £40 all in, but it's night and day in terms of stopping power compared to the crappy ones it comes with. And in future i can just swap the pads, so it's quite a lot cheaper then.
Saddle wise, it's pretty personal. I put a Charge Spoon on mine which i seem to get on with.
My Defy 2 came with cheapy plastic clip pedals, probably put on by the store. Ditched them for clipless SPDs - Shimano A530.
Can confirm it was, yet again, a pinch flat! Need to lose some weight and/or highway maintenance need to fix the roads :) that and obviously my tyre pressure may be on the low side since my pump broke.
I shall have a play about with my saddle to see if I can get it more comfortable before looking at replacing it.
I read somewhere earlier about Kool Stop Salmon pads, that are supposed to be good with the Shimano 105 brakes!?
Does anyone here own any Carbon Tubular wheels at all, in particular ones ordered through China?
What's your views on them and which company did you order through?
I have had some in the past, but i'v since sold them on.
I bought them on ebay, cant remember which seller. They were around £270 including postage (and i dont think i had to pay any import duty on top of that - they were marked as commercial samples). Remember to factor in the cost of tubular tyres as well, it'll be around £50-60 each for a decent tyre.
I had skinny 21mm tyres on them at around 150psi. This made them fairly uncomfortable and a bit twitchy, but fast.
I only used them for racing (and i wouldnt recommend tubulars for general riding) so i probably only did around 3-400 miles on them. They held up well in that time though, they took some pretty big hits (if there are people riding on either side of you in a bunch race, there's no way to avoid potholes) and never felt floppy or flexy. The bearings were smooth, but they didnt get enough use for a proper review really.
They came with skewers and also a set of brake pads for carbon rims (which were rubbish when wet - but then most wheels with carbon braking surfaces are).
Yup, Kool Stop and Swisstop seemed to be the commonly recommended ones. Think you'll be fine with either.
Regarding the saddle comfort - have you had a bike fit done to make sure it's in the right position in terms of height & fore/aft? That can make a big difference. Also, make sure it's level. The temptation is to point it downwards if you're uncomfortable, but that will generally make it worse in reality.
Cheers for that, I would only be using them as race wheels too - did you have any long descents on them with heavy constant braking? Worried about warping and delamination from the heat generated
Farsports have the best reputation, but most of them come from the same factory/mould really
Lots of info here
https://www.lfgss.com/thread20845.html
https://www.lfgss.com/thread61471.html
I'm in contact with Kyle from Farsports at the moment re a set. I'll read through those threads and see if I come up with any more information.
I'm tempted to just order rims from e-bay drilled 24f and 28r and build them up myself. Most, if not all, of the ready made wheelsets are 20f and 24r but I wouldn't trust them at my weight despite being within there guideline weight limits.
No, didnt really have any hills long enough to worry about that.
I had 38mm rims with 20/24 spokes. I was around 14 stone at the time. According to the datasheet, the weight limit for 38mm rims was 100kg.
I may well have a look at those then come pay day this month...
I've not had a bike fit, no. I do know where my saddle should be height wise in relation to the bend in my knee etc and also my knee to be over the pedal axle when horizontal. I just need to fine tune it I think, but need a helper as I don't have a stand of sorts.
I think my seat may be pointing down slightly so will adjust that later on and see how I get on.
Cheers :)
Diva, the Allez will have a geometry chart on the Speciaized website. Ribble also publishes their geometry for every model.
Basically you need to make sure the new bike you want has nearly the same dimensions.
If you know what new model you want and post both geometries on here and let people know which size Allez you have then someone will be able to help if you are struggling.
Thanks for the reply.
I've got the geometry fro my exisitng bike and the ribble bike I'm looking at.
they don't make a great deal of sense to me could someone be so kind to have a look over them for me ? Allez was 56 Cm frame (Large)
allez geo
ribble frame
ribble geo
Status
