- 29 Dec 2004
- Shepley
The large Ribble is going to be closest to a 56cm Allez, but that depends on whether your current bike feels comfortable to you or not.
Damien, large ribble, 130mm stem.
So its of a similar design and fit?
The Allez is fine ridden over 3k miles on it so should be OK![]()
, my main reason for it is i only want to know my watts, during my time trail DVD and sprint
Yea sorry, i mean so i can load my 3LC DVDs up and then do them whilst trainer road is running in the background. Ive only had a play at my desk moving the magnet past the sensor by hand, my main reason for it is i only want to know my watts, during my time trail DVD and sprint
40mm or 50mm deep No Logo rims or Espresso deep V's are probably better value than those. Apart from the hollow axle, Nova tech hubs are identical to a whole host of other track hubs (e.g. System EX, Zenith, Halo) and they're all pretty silky smooth on the bearings. I've done a LOT of miles on mine and not had to touch them yet. Just check you get your choice of braking surface, because I think Espressos don't come with a braking surface.Getting sick of waiting for Halo Aerorage to get instock and was wondering if this wheelset is good enough?
https://parkersofbolton.co.uk/p-2190-700c-pegasus-single-speed-fixie-flip-flop-wheels-black.aspx
Gonna fit it to a Kona Paddywagon as my rear wheel is currently a bit dodgy.
Such heavy wheels though lol.
Proper annoyed!
There was a Strava segment i was joint KOM with someone else, beat them last week and now was top on my own.
They have now flagged it as unsafe as it goes through a mini roundabout and created a new one that ends before the roundabout and give it the same name but added SAFE at the end....surprise surprise they are now KOM on that.
I think he commutes via the segment sometimes when there is going to be a tailwind but his commute times are when its rush hour so he could never beat my time as the roundabout was too busy and i commute past that point at 6.15am.
Do Strava review it and decide whether to reinstate it at some point?
Just ride his segment and beat it?
