- 26 Aug 2012
- North West
Have they all been from the same manufacture date and revision ? Seems really weird that 3 would do the same.
All same batch from Amazon.
Do you just do that in windows? You don't mean the normal left and right split do you as that wouldn't be 720p right? I'm assuming top and bottom?
Cheers![]()
I would get it replaced by Dell then you should get one from a different batch.
I have two Dells running side by side, and no had any issues with them at all. Both are calibrated and are excellent, an improvement on my older Dell 2709W.
Thankyou both for your responses.
I gotta be honest I'm at a bit of a standstill now. Cannot make up my mind on whether I want two monitors, three monitors, different sized/the same size. It's driving me insane!!!
It's not great if you are still having problems, especially for the money. I have also heard about the PWM lighting which is a plus I guess for the Dell?
Thanks![]()
Which Dell?
Thanks![]()
Sorry, dell 2713hm.
