You've got my result with the CPU at 4.2, it's actually at 4.5![]()
Cheers and sorted
2 way sli on this with a pair of Titans is the score we want to see.![]()
I forgot to say earlier, thanks for putting this together and spending the time keeping it updated![]()
Maybe the weekend will start to show some Titan scores![]()
2 is the optinum number on this any more and it will be like my 690s negative scaling. Until nvidia get the drivers sorted anyway.
I am not sure it is the drivers Kaap. Both Nvidia and AMD give bad results with 3 cards or more. I expect an update from Futuremark that sorts it. I could be wrong though (wouldn't be the first time)![]()
No problem and I enjoy doing it. I am not happy seeing all those 7970's dominate though![]()
I'm trying to put a 7950 up there...!![]()
I don't know if I can push any more from my card or CPU...
http://www.3dmark.com/fs/208031
Hardware as before, but now:
Core i5-3570K @ 4.6GHz
7950 @ 1250/1650
I haven't got mine past 1200MHz stable on the core yet - temps are good though with the full cover water block, I think I can't pump enough voltage into it - even 1.3v set in Afterburner drops down to ~1.18v under full load.
Considering putting a HD7770 in my pc as there hasn't been one entry yet for that card here. I could be in first place, untouchable.
Do it. I wouldn't mind seeing how it fairs up to top end GPU's. If someone has a tight budget, it could be the new recommendation on this score![]()
