**Official Unigine Valley Leaderboard**
That's a bit low isn't it? I'm running 2x6950s at 6970 speeds and I get a higher score than that.
Does seem a bit wonky for some reason, might have to run it again to see if anything changes.
ED: afterburners reporting only a 60%ish load on each gpu at the minute, so im losing quite a bit of performance.
New score
HD 7970 x 2 @1270/1850
3970X @4.9
1635 score with 1125/1575 overclock on a reference 7970 seem low to you guys?
Extreme HD Preset
Driver: 13.2 beta 6 (driver swept)
Temps: 73c
Voltage: 1050 (stock) to 1175
So i did a clean install of windows 7 and know im getting decent scores.
I managed to get to 1200/1600 @ 1225 voltage, temps 76c and a score 2067
Im thinking if getting a artic accelero xtreme cos the noise from the reference fan is ridiculous. How much further you reckon i could push it with the xtreme?
Right then disabled the bottom 2 cards (pulled the power out :D)
125 strap + 105 Host frequency= 130mhz BCLK+PCIE x 38 cpu got me 5000mhz
3930k @ 5000mhz
GPU @ 1390mhz/1950 1.38v (artifact central)
I'm going to have to revisit this once my new vrm heat sinks arrive. At my limit now, but ill be back. Be afraid Locky, be afraid!! :D
I really wish I could get this to work with all the cards in, but I just get a black screen, Windows loads up perfect and everything - just a black screen.
Probably putting way too much strain on the motherboard/gpu's with three cards running at 105BLK.
I'm familiar with BLK on sandybridge but the strap (unless locky is referring to a jock strap) not so much. I vaguely remember a fsb strap from my socket 775 days but that was so long ago its since been forgotten.
Is it the CPU's Internal clock speed, What you used to call the FSB and i call the HT-Link Bus.
But does it allow for a more stable GPU clock?
because at the moment im sure you all have the same issues as me when you get to 1300+ that the Thing is artifacting like a disco show.
Thats why my max score is on a 1260 overclock as that's stable and no artifacts.
I remember fsb-nb strap settings on s775, board was a p45 chipset asus p5q deluxe.
