I'm at work so can't check the shop forums but does anyone know of the new offers are live.
YES, but don`t` see anything that would benefit you.
http://www.overclockers.co.uk/news.php
Final spec then guys. Looks fine?
Looks good, not entirely sure why you don't go for a Z77 board like in my spec?
It gives you the option of overclocking if you feel you want it in the future
A few reasons though:
Gigabyte board is off better quality and better warranty
Supports PCIE-3 (if that interests you)
Native USB 3 and SATA 3 (unsure if the B75 uses 3rd party USB 3 and SATA 3 tech like the h61 which is slower)
PCI lanes
4 DIMM slots
You choice though, if you want to save money then you can grab the B75.
1 x PCI Express 3.0 x16 slot (PCIE1: x16 mode)
- 1 x PCI Express 2.0 x16 slot (PCIE2: x4 mode)
- 2 x PCI slots
- Supports AMD Quad CrossFireX™ and CrossFireX™
1 x SATA3 6.0 Gb/s connector by Intel® B75, supports NCQ, AHCI and Hot Plug functions
- 2 x SATA3 6.0 Gb/s connectors by ASMedia ASM1061, support NCQ, AHCI and Hot Plug functions
Just looking at the specs for the B75 Pro, for an extra £3 you get a few extra benefits.
4 dimm slots, USB 3.0 header, handy if your case has a USB 3 port. Have a look at the specs and see for yourself.
http://www.asrock.com/mb/Intel/B75 Pro3/?cat=Specifications
Yeah that sounds good. For such a small increase on price I'll go with that, can you link me please so I know I've got the right one.![]()
Yeah I think I'll just stick with the normal board.
I will end up putting an i5 in there but I won't be overclocking and I won't really be in any rush to do so.
So the above spec will certainly be able to play modern games on decent settings with smooth FPS?
Howcome you won't go for the cheaper MSI OC 7850? It will perform better I imagine and 3 year warranty.
