Final Build Spec - £450. System Only.
Final spec then guys. Looks fine?
It looks fine, if you are not planning to overclock the i5 in the future then that board is alright.
For future reference, don't bother with a 3570k in the future without a Z77 board, you would be better off just getting a i5 3350p, since both are pretty much identical except a 3570k can be OC'd like a mofo.
I also really like that case, my mate has one :D
I honestly don't understand the specifics but why do I need a Z77? I don't think I'll ever overclock. :)
And I'm already on a tight budget so need to save pennies.
It gives you the option of overclocking if you feel you want it in the future :)
A few reasons though:
Gigabyte board is off better quality and better warranty
Supports PCIE-3 (if that interests you)
Native USB 3 and SATA 3 (unsure if the B75 uses 3rd party USB 3 and SATA 3 tech like the h61 which is slower)
PCI lanes
4 DIMM slots
You choice though, if you want to save money then you can grab the B75.
Yeah I think I'll just stick with the normal board. :)
I will end up putting an i5 in there but I won't be overclocking and I won't really be in any rush to do so. :)
So the above spec will certainly be able to play modern games on decent settings with smooth FPS?
PCI lanes
4 DIMM slots
1 x PCI Express 3.0 x16 slot (PCIE1: x16 mode)
- 1 x PCI Express 2.0 x16 slot (PCIE2: x4 mode)
- 2 x PCI slots
- Supports AMD Quad CrossFireX™ and CrossFireX™
1 x SATA3 6.0 Gb/s connector by Intel® B75, supports NCQ, AHCI and Hot Plug functions
- 2 x SATA3 6.0 Gb/s connectors by ASMedia ASM1061, support NCQ, AHCI and Hot Plug functions
Does`nt have USB 3.0 header on the mobo.
Yes, one of my systems is a Z77, i3 3220 and a 7850, runs skyrim, bf3 etc all on ultra 1080p.
Can someone confirm the above is all good and I definitely can't get anything better/different for the money? :)
Is the Z9 the best case to go for for the price?
Cheers
Howcome you won't go for the cheaper MSI OC 7850? It will perform better I imagine and 3 year warranty. Oh it's back up in price, ignore.
