I will stretch to £2k if I can find something special.
How much dollar does it involve to make a MX5 shift quicker?
Are RX8's a massive no no? Does the rotary engine show signs without having to do a compression test?
The advantage of an MX5 is that you can have a lot of fun at sensible speeds. They're also very capable on track, despite their lack of straight line speed. That said, they're not exactly horrendously slow either.
) and take it around a wet donington and you'll have bags of fun at very low speeds:I would have though RX8s for that sort of money would be sheds?
Curveball option - Porsche 924 or 944? Have seen a few stripped out as trackday toys.
They are beyond horrendously slow in N/A form![]()
In comparison to what? A 328i? Of course. A Ford Focus? No
"Slow" is a relative term.
Very true, but a ford focus is very slow also
I see what you're saying, but I don't consider the 328 to be a fast car either, not when I'm getting out dragged by Clios down the straight anyway![]()
Glad this thread appeared, always had a hankering for a 182 just to do track days in.
Rang the Clio up, he says the engine rattles and makes a horrible noise on start up. Pulley I am guessing?
Seemed very nervous speaking to me which isn't normal for a trader? Not sure if to go look at it or not now, pulley doesn't put me off, his confidence talking about it did though...
Indicators will be the same, they are still on the right hand side on UK models too. Although don't know if all models have the adjustable steering column.
Was a car we took in my old job, thought it was an import because the indicator was on the right.
Its normally the dephaser pulley that goes, although thats normally when warm rather than start up. If it somehow was that you are looking around £600 to sort.
