Appear to have lost 20GB
16 May 2011
Staffordshire
Hi,
I'm trying to free some space on my main boot drive (OCZ Vertex 4 256GB) and have found that somewhere there is over 20GB of space unaccounted for. Any ideas what this could be?
The picture to the left shows the summary of the root of C:/ drive including hidden folders.
pagefile? 16gb of ram = 16gb of pagefile,reduce it to 2.5gb if i were you
disabling sleep will save you some more
Thanks for the suggestions
Just looked at pagefile which says it is currently allocated 2304MB?
Sleep has always been disabled
Any other ideas?
EDIT: I am running Windows 8 by the way
Hmm... That is odd.
Just out of interest I checked mine Samsung 250 (non-pro) and mine only shows 232Gig.
I have 23Gig allocated for over-provisioning so 209 for use. (win 7)
I'd say pagefile, and system restore files.
As you have 16GB ram, I'd turn the page file off completely, and set windows backup to only hold onto the last couple of restore points rather than all of them...
Ok I have now accounted for the space using space sniffer as was suggested.
This showed two rather large files (hiberfil.sys & pagefil.sys) and various other smaller hidden files which don't show up in windows explorer.
I have turned off hibernate to remove hiberfil.sys as it only saves around 5 seconds off boot time which has gained me 16GB
As for pagefile.sys i have turned it off as suggested and also set the space allowed for system restore(or system protection as in windows 8) to a minimum.
Thanks for all the suggestion! Plenty of space to install Crysis 3 now when my gfx card returns from RMA!
