5.25" sata hot swap drive bay.
14 Apr 2011
Newark
As title, looking for a decent single or dual 3.5 sata drive bay.
Anyone got any recommendations, I want to put one in my P280.
might get my fingers burnt
google startech 5.25" dock
itll pop up just checked
Cheers for that, found that one earlier. should have mentioned, I need one that the drives slot into completely and not stick out, as I don`t want to leave the door open on the case.
Got this the other week, what an absolute piece of junk.
The flap that stops dust getting when not using an ssd, is just a bit of cheap plastic, which does stay in place.
The eject buttons are a little stiff but the one for the ssd is ridiculous. The first time I pressed it, the ssd flew out across the room, just missing my face.
And inserting a hdd is not always easy, iy seems to catch on something, so you have to jiggle it about.
I even wrote to ICYDOCK and as you can imagine, I have not heard back, nor do I expect to.
So just waiting to hear back from the retailer and get a full refund.
Ohh god,I didn't think they were that bad,I use a startech one myself and its been great,havnt used an icydock though
I feel bad cos I recommended it,its a shame the startech one has the drives sticking out
I was actually looking at it before you posted, so nothing for you to feel bad about. :)
It`s just one of those things, trial and error, besides ti looked good in their video. :rolleyes:
