my 7950 windforce x3 is oc to 1200mhz and has no problems with heat or power but at random the game will lock up and crash to desktop
not so annoying single player but during multiplayer matches its annoying no idea whats causing it
Quite possibly an unstable OC be it the gpu/cpu oc or both.
What's stable in other games/BM's may not be stable in a very, very demanding title that Crysis 3 is.
Put your clocks down to 1050 or so and test again, if it doesn't crash you know it's the clocks, if it does then it may well be a driver/game issue.
Any tips for Eyefinity 1080 res on a 6970? It's going to chug I'm sure.
Well, it seems I probably won't be able to play the game at all. I'm stuck on 11.12 as every Ati driver after that has serious microstutter issues with WoW and Eyefinity. I play WoW more than anything else so meh.
Think I'll by an nVidia card.
1080p with SMAAx1 - 38fps
1440p no AA - 28fps
I expected it to be lower than with AA but it feels more stable and consistent. Surprised it's lower than the 670, maybe it's something I have set in CCC.
maximum settings on my rig @ 1920x1200 = 18fps (with 8xAA)
What card do you have?
7970.
The 7970 is clocked to 1200 too. It's probably my 8350 letting me down in that level. CPU usage is low (~20%) so the rain effect probably needs raw IPC or something.
