Permabanned
- 9 Jun 2009
- London, McLaren or Radical
I like to think logic is consistent is just that we all do it wrong.![]()
One way to look at it - but I prefer to think logic is subjective.
There is likely a strictly defined way that everything works... it's our arrogance that we already understand the principles and just need to fill in the blanks that annoys me. Without questioning the greater picture, where will new ideas come from?
I guess another way to phrase your viewpoint would be:
"true logic is directly linked to the one true understanding"
Apologies if I got the wrong end of the stick.
Not exactly, it's just a conclusion drawn from the expanding nature of the universe. For the most part you'll get a "we don't know what happened before that".
However if you follow this process to its conclusion at some point you hit the barrier of "OK, something came from nothing" or "something has just always been". This is the same thought process as "god came from nothing" or "god has always been".
I think most atheists will accept thats a complete and utter mind ****. They just don't believe that adding god in helps it make any more sense.
A fair way to put it, we don't disagree here... I'd just add that in my opinion, both opinions are a logical conclusion - even though they both require leaps of faith.
The observer effect is a complete and utter mind ****. It's like magic to me, I really don't understand how that can happen. However it doesn't do anything for me to start looking for a higher power.
For me it's specifically the link that a conscious observation affects the outcome.
For this to happen, it suggests a particle interaction outside of our normal experience of time.
Alternately - if consciousness is a part of everything - perhaps even the fundamental building blocks of the universe - perhaps the base string is a portion of a conscious projection (hologram).
If it is all made of the same, conscious, building blocks - then the interaction does not have to be outside of our standard time reference.
Perhaps either the collective consciousness decides the outcome or allows us to access the outcome relevant to that observation.
If you're interested in these ideas - I suggest "The Quantum Activist" by Amit Goswami. His ideas differ slightly in certain aspects, but the main ideas are very similar.
This then lead me to think about zero point / vacuum energy. What if these dualistic explosions of perfectly opposing energetic particles are explosions of consciousness?
What if the universe is a growing organism, the whole thing is conscious.
I've never liked the theory of inflation and always found the importance of fractals to this universe to be very interesting. Cell division feels like it is a better explanation than inflation.
When you look at the structure of galaxy super-clusters - they look almost identical to brain neuron structure.
Then I started thinking about purpose... it just started to seem that there are too many coincidences on this tiny planet for it to be independent of any influence. Sure it could be explained and random chance in a sea of probabilities, I just don't think that anymore.
The point I'm going to make has been raised a lot of times on this forum but it fits perfectly with this. Many elite scientists from the past, all smarter than me, have turned to god when they've reached the limit of their understanding.
I believe it's your ego that makes you go to a higher power because you don't want to accept you don't know the answers when it's possible to figure out. We probably won't know the answer in our lifetime but I'm willing to bet someone will figure it out.
This video is posted a lot, but it's worth the watch to show my point:
Better men than I have been folly to such thinking.
It may well be that simple and I would have continued to think along similar lines had it not been for the very direct experience I mentioned above.
Take it for what you want, I know even only a couple of months ago that I wouldn't have believed what I typed in my last post.
