**LONG WEEKEND ONLY DEALS - GIGABYTE AMD GRAPHICS CARDS!!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Well I'm going away for a long weekend break, won't be back until Tuesday, as such thought I'd post some pretty hot deals up on Gigabyte AMD/ATI graphics cards:-
Gigabyte ATI Radeon HD 7970 GHz Edition Windforce 3X 3072MB GDDR5 PCI-Express Graphics Card with Crysis 3 & Bioshock PC Games @ £339.95 inc VAT
GIGABYTE introduces the latest exclusive "Triangle Cool" Technology to reach a better cooling performance. The latest patent pending technology combines fin with clip module in a special triangle shape. With the original anti-turbulence structure plus the new triangle cooling design, it enhances the efficiency of heat dissipation dramatically by minimizing the flow of turbulence between fans. Therefore, the "Triangle Cool" Technology provides a more efficient air flow for the cooling system.
Ultra Durable VGA board provides dramatic cooling effect on lowering both GPU and memory temperature by doubling the copper inner layer of PCB. GIGABYTE Ultra Durable VGA can lower GPU temperature by 5% to 10%.
Ultra Durable VGA board reduces voltage ripples in normal and transient state, thus effectively lowers noises and ensures higher overclocking capability. GIGABYTE Ultra Durable VGA graphic accelerators improve overclocking capability by 10% to 30%.
Ultra Durable VGA board allows more bandwidth for electron passage and reduces circuit impedance. The less circuit impedance, the more stable flow of current and can effectively improve power efficiency. GIGABYTE Ultra Durable VGA can lower power switching loss by 10% to 30%.
Features:-
- PCI-E 3.0 Ready: Delivers double the bandwidth per lane of PCIe GEN2 for faster GPU- CPU
- Fastest single GPU graphics card on the planet
- Hugely overclockable
- Vastly cooler running than previous generation
- Quieter running than previous generation
- Compute Power: 3.5 TFLOPS
- Core Clock Speed: 1100MHz
- Primitive Rate: 2 prim / clk
- Shader Architecture: GCN
- Stream Processors: 32 CU / 2048 ALU
- Texture Units: 128
- ROPS / Z-Stencil: 32 / 128
- Frame Buffer / Memory: 3GB GDDR5
- Memory Width / Speed: 384 bit / 6000MHz
- Load / Idle Board Power: <300W / <3W
- Power Connectors: 8-pin + 6-pin
- Dimensions: H=38 mm, L=285 mm, W=126 mm
- Display Outputs: 1xDVI + 2x mDP + 1x HDMI
- 3yr Warranty
Was [£399.95] Inc. VAT
Only £339.95 inc VAT.
ORDER NOW
Gigabyte ATI Radeon HD 7970 Windforce 3X 3072MB GDDR5 PCI-Express Graphics Card with Crysis 3 & Bioshock PC Games @ £299.99 inc VAT
Features:-
- Core Clock Speed: 1000MHz
- Memory Width / Speed: 384 bit / 5500MHz
- 3yr Warranty
Was [£359.99] Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
Gigabyte ATi Radeon HD 7950 Windforce 3X 3072MB GDDR5 PCI-Express Graphics Card with Crysis 3 & Bioshock PC Games @ £239.99 inc VAT
Features:-
- Core Clock: 900MHz
- Memory: 3072MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Memory Interface: 384-Bit
- Processing Cores: 1792
- Bus Type: PCI-Express 3.0
- Display Connectors: 1x Dual Link DVI, 1x HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.2 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Warranty: 3 Years
Was [£275.99] Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
This crazy low pricing will end next Tuesday, or earlier if stock sells out!!
Remember were still supplying Crysis 3 and Bioshock with all orders!!
BUY NOW!!!!!!!!!!!!! :D :D :D :D :D
Phwwooooar they are some very tempting deals! Great job Gibbo!
I don't think I'm in the best position to be buying a new GPU at the moment though.
Mental pricing on these, 299 for a 7970 with games, voltage locked or not that's awesome!
trouble is I already own one lol
Yep especially as now exchange rate has dropped from 1.58 (my current stock) down to 1.50 which means new stock is a lot more expensive.
Makes these deals even better!!
whats teh usa exchange rate got to do with that ? if your importing from the usa wont the current be different ? ( excuse my ignorance on this )
Product we buy like VGA comes from far east/US, as such it is sold to us in USD (American Dollars).
So if a product cost $400
When the rate is 1.60 our cost would be 400/1.60 = £250.00
When the rate is 1.50 like it is now our cost is 400/1.50 = £266.66
So as you can see this forces the cost of the product higher by £16.66 and this is why in the UK fuel prices and computer components are moving upwards in prices quite a bit from where they were a few weeks ago.
If the rate drops to 1.40ish, prices will go even higher.
If the rate recovers to 1.60ish then prices will come back down.
Understand it better now?
It shouldn't affect price but the North Atlantic drift could make them arrive colder or warmer :)
Trying to stop myself upgrading, and this is not helping, that 7970 is soooooo tempting at that price.
Worth the extra £40 for the GHz edition?
It's the same card, just comes a little bit higher stock. Just clock the other one and put the £40 elsewhere. :)
p.s. unreal price on the 7970s. Sell your gamecode for £35 or so and you just a 7970 @ £265!
The GHZ edition is worth it if you want the guaranteed 1100 Mhz speed the no GHZ edition won't necessarly reach 1100 these cards are now voltage locked, my non Ghz edition will only hit 1060-70 stable but memory hits 1500 so it's all good.
