Nice cards.
Love the performance.
I still dislike the price though.
Cool story bro. Heard that one before though - can we have a new one?
Nice cards.
Come and join us Rossi, Matt and Rusty. We want more company.
I will only be using a single PSU, I have one of these on order.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-000-EA&groupid=701&catid=123
The thing that made my mind up was that everything is reversed which makes cooling the CPU a lot easier plus if I get a leak it won't go all over the cards/mobo. It also means the cards are the other way up, no backplates required but if I stick with air the GeForce logo will look a bit odd upside down.
As to using screws to hold the side panel, I don't like the idea either but I can't win them all.![]()
It is a nice idea (two rads in the bottom) however, my experiences with the TJ11 are that unless you are willing to custom cut all of your power cables, you will only be able to fit a single rad in the bottom.
Played some more FC3 last night, although a Titan could run it twice at the same time, I still can not get it perfect. Anyone else tried found some secret tweak settings ?![]()
I had that trouble except for when I used the 313.95 drivers on the 680's. Yoou could try the 313.93 drivers that were the original Titan drivers but other than new drivers, it will not play smooth.
Stupid fps still = the odd stutter.
Which drivers are you using for your Titans.
I have only used the original Release drivers for mine
Is that the 313.93 drivers
Thanks
