Can chkdsk repair my faulty HDD??
4 Mar 2013
Geordie Land
Hello everyone
I'm having some trouble with my laptop, it won't boot into windows after the acer logo it will black screen and eventually go into startup repair. I've managed to work out that the hard drive is faulty by going into mini xp and using hd tune to scan the hard drive. There were 2 damaged (red) sectors.
I've been told by a colleague that running check disk may solve the problem. I am currently running chkdsk from the cmd prompt in start up repair and it seems to be stuck in stage 2 of 5 (10%). It's been running for 45mins.
My question is can chkdsk save my hard drive or should i prepare to buy a new one?
I'm a bit of a novice and am still learning so be easy ;)
Any feedback will be appreciated.
all it does is find errors, and when found mark them bad, repair is rare but does happen, normally if it repairs then it wasn't damaged just bad links etc which it fixes and says repaired but unless you look at the error message sometimes you think it's fixed something major with most of the time if any it doesn't
http://en.wikipedia.org/wiki/CHKDSK
Steve Gibson's SpinRite is a good one to try
Had a HDD that wouldn't boot into Windows, would crash trying to install/re-format Windows too.
Tried accessing it, would crash.
Ran chkdsk about 4 times and managed to get it working to get the data off.
Drives are cheap anyway but if a problem, you can partition it and use it as a spare but not sure it is worth the hassle.
