I use the following in the game launch options through steam for an i7. For the Q6600 I'd change the cpucount to 4 and remove the memory setting as by default arma 3 uses 4GB anyway I think.
-cpucount=8 -nosplash -high -maxMem=8192 -exThreads=7
Also I've manually set PhysX to my GPU rather than auto select. Running the above settings at 4.8GHz I average 50 fps on most servers with CPU usage between 80-100 and GPU clocks at full speed rather than idling speed.
with two guys keefo and andy.Great fun on MGT wasteland server just nowwith two guys keefo and andy.
I'll defo be playing that again tomorrow!
Dude MUST add you on steam when I got home. Was running around in your sqd last night spamming chat but no response :/
Sucks that I have opted into the beta and now the OCUK servers are a different version![]()
12-03-2013
• Cross-joining default and Development branch disabled in MP
• Ifrit config class names changed to O_Ifrit_F and similar
• Various artwork fixes and tweaks in materials, textures and passenger animations
• Active Development branch is now indicated in the main menu
• Various other showcase fixes
• Multiple crash opportunities fixed
Snow is already in the game mate...
Set it to winter time, and rain.. Instead of raining it snows! Although the snow doesn't lie on the ground!
Anyway, I think my tasks are becoming mighty complicated
I have cancelled missions, if the task isn't complete. I have a separate mission for divers that need to be done before the land troops move in! Back up exfil points etc!
Implemented Tonics VAS script, saved loadouts etc!
Got supply helis flying in and choice of landing zones for initial infil..
Got to make up my mind what patrol script to use, either UPS or VSPS. Either or will do, but trying to make it as light as possible on fps.
Speaking of that. I am making a terrain and distance dialog, that will allow you to obviously change view distance on the fly, and also the amount of grass that is there..
Will update as soon as I am closer to release!
IF server signing is on , if you have the wrong build you cannot connect to that server (as ours is configured)
Summary:
Unable to utilise binoculars while on a vehicle
Description:
Example, while pillion on a quad, I am unable to use binoculars. I have to eject from the Quad before I can use them.
