Hi Guys
We have new special pricing on our best selling system cooling solutions
The Antec spot cool is a classic design that has been a hit in enthusiast computing for years.
Perfect for benchmarking or low airflow systems with hot spots on the board and vga cards
Antec SpotCool 80 System Cooler @ £8.99 inc VAT
Antec's Spot Cool is specifically designed to mount on any motherboard to provide cooling wherever you need it most. Simply mount it on a motherboard mounting hole, angle the fan as you desire and power it from a motherboard fan connector. The 3-speed switch lets you balance quiet performance with maximum cooling. Get active cooling for your RAM, or expansion cards, or wherever your system needs it, and you'll see even better performance.
- Mount virtually anywhere inside a case
- Cools RAM & expansion cards
- Blue LED illumination
- Air Flow: 22.2CFM / 18.2CFM / 15.3CFM
- Speed: 3000RPM / 2500RPM / 2000RPM
- Acoustical Noise: 32.7dBA / 26.6dBA / 23.2dBA
Only £8.99 inc VAT.
ORDER NOW
Antec Spot Cool 100 System Cooler @ £10.99 inc VAT
Antec's Spot Cool 100 provides your component of choice with a smart, targeted cooling solution. Specifically designed to mount on any motherboard, Spot Cool 100 delivers precise cooling with its easy-bend arm and rotatable head, and it makes a flashy addition to any enclosure with its blue LED fan. Simply mount it using any motherboard mounting screw, angle the fan as you desire and power it from a motherboard fan connector. A dual-mode switch lets you choose between full-speed cooling and thermal sensor mode, which adjusts fan speed according to temperature. Get active cooling for your component with Spot Cool 100 and achieve better performance.
- Mounts virtually anywhere inside a case to cool your RAM, chipset, graphics cards, etc.
- Flexible head and arm allow you to aim your Spot Cool fan anywhere you want to
- 100 mm low-noise fan provides Quiet Computing™
- Dual-mode switch allows you to choose either full-speed or thermal sensor mode
- Thermal sensor mode adjusts fan speed according to temperature
- Cable Length: 5.5" (140 mm)
Only £10.99 inc VAT.
ORDER NOW
Only £8.99 inc VAT.
ORDER NOW
ORDER NOW
