tool for brake caliper
26 Aug 2010
Hi
I'm going to attempt to change my own pads on my van. Every time i've had them changed they used a tool to put the piston looking things back into the caliper (or what ever there called) the front ones can just be pushed in but the back they use a tool the screws them in anti clockwise. Does anyone know the name of the tool and where I can get one from? I'm guessing it's a specialised tool so I can't just get it from anywhere?
Thanks for any help
To break it quickly and efficiently I recommend a nut cracker....
Or try a caliper piston rewind tool.
Cheaper way of doing it is to use a screwdriver or chisel on it's side across the grooves to wind it back. Works everytime for me.
I've hot that same one on my watch list now.
You can use a g clamp on the front but not the back. It's my mates garage were I take my van so I watch what he's doing. Unless it's a few hour job
Even tho he's a mate the money is better off in my pocket
