- 28 Feb 2013
- Birmingham
That's their 29" monitor.
I see, my mistake then.
you had to throw that in the mix didnt you.![]()
I assume the dell is a 1600P?
If so, it could pay to get 7970/50CF if you don't mind a little bit of stutter. Lots say that microstutter isn't noticable though.
For me, I would get another 680 and SLI those bad boys![]()
I cant find another gainward model anywhere i was looking at the evga, but for abit more i could get 7970s aswell.
+1
I use a dell u3011 as well, I use GTX 690s on it and don't normally have a vram problem. At 1600p 2 x GTX 680s or HD 7970s will run out of GPU muscle before they reach 2gb of vram usage.
I would just get another GTX 680.
GPU power and RAM usage aren't linked in the way people commonly portray around here though.
Yeah i use the dell u3011 to.
My 2gb vram cards work fine for me @1600p![]()
@Spoffle, wasn't me bud.![]()
I never suggested they didn't, it was the notion that you need a certain amount of GPU power to push or make the most use out of a certain amount of VRAM that I see commonly suggested around here that I was taking issue with.
Comments like "you'll run out of GPU power before you hit the RAM limit" implies that GPU power strongly influences the amount of VRAM used.
No it doesn't. It means that to get playable FPS due to raw grunt lacking you'll need to lower settings which in turn removes you away from the VRAM limit.
You know this you're just being antagonistic.
the 7950 looks a good move to, also this will be the last upgrade i will do to the system for a loong while.
