I'd be concerned with a HDD that the movement of a car would scratch/damage the HDD.
Better tell Audi to stop putting them in their MMI systems then!
Mine has both front and rear, and since the bluetooth module is USB, and needs to be in all the time, it means you always have an unsightly module sticking out the front as I much prefer to have the ipod stashed away!
DO WANT!
I assume these don't glow?
Shouldn't you care more about the fact you have a massive gapping hole than the length of a USB stick? It's that like putting glitter on a turd?
	Check out the epic wood!
