The description of the 1220 states that it supports socket 2011, the title does not. Just reported it
The Antec product page clearly states that it supports socket 2011, and the product title of the Kuhler 1220 should be updated shortly![]()
As I say it would be a tight squeeze in the 300R and for the cost of it a good air cooler would make more sense.train wreck![]()
Not sure why people are using the antec 1220 CLC as it doesn't list socket 2011 support for their mobos, the H100i from corsair does however.
The Antec 1220 certainly does support 2011.
I've stopped being lazy but still can't find reviews online to link for the CLC. It was the choice of case they were putting it in that originally bothered me.
We've covered that already stulidI've stopped being lazy but still can't find reviews online to link for the CLC. It was the choice of case they were putting it in that originally bothered me.
I'd like to see your take on the budget![]()
How do you get it to paste into the thread all nice like that?
Did you just edit it ?
Nice setup, only things i dont need from it will be windows 8, and then just to buy a new mouse, kayboard and monitor![]()
For 3D design work NVIDIA is the way to go (if sticking to gaming GPU's). CUDA works better than open gl in my eyes..
Yeah 1k-2k is a big gap.. Narrowing it down may help.
Are you happy to build it yourself?
Well ive had a look through all the options, and this is what ive come up with/planned to buy.
www.overclockers.co.uk/showproduct.php?prodid=CP-395-IN
http://www.overclockers.co.uk/showproduct.php?prodid=CP-395-IN
http://www.overclockers.co.uk/showproduct.php?prodid=MO-051-BQ
http://www.overclockers.co.uk/showproduct.php?prodid=HD-159-SA
http://www.overclockers.co.uk/showproduct.php?prodid=MB-219-MS
http://www.overclockers.co.uk/showproduct.php?prodid=CA-036-CS
http://www.overclockers.co.uk/showproduct.php?prodid=CA-000-XF
http://www.overclockers.co.uk/showproduct.php?prodid=HS-009-AN
http://www.overclockers.co.uk/showproduct.php?prodid=KB-077-RA
http://www.overclockers.co.uk/showproduct.php?prodid=KB-078-RA
http://www.overclockers.co.uk/showproduct.php?prodid=MY-132-KS
Comes to a total of £2,054.78 Inc VAT.
I have already got a HDD & DVD-RW.
Also the mobo is socket 1155 not socket 2011 so the CPU won't fit itCan you use the basket tool stulid linked in post #34?
Looks like you are buying three 3930Ks from that postAlso the mobo is socket 1155 not socket 2011 so the CPU won't fit it
