- 24 Sep 2005
- Middlesbrough
Sod your Dad and pay for the car yourself. It's your car!
If you can't afford it then cycle.
I can see spider cracks from the epicentre of the damage, they appear to spread outside of the photo aperture. If I'm seeing what I think I'm seeing, then yes it is most definately an MOT failure it is a stuctural piece of safety glass.
Whilst sitting in the driver's seat and, referring to the diagram below, examine the driver's view of the road through the swept area of the windscreen.
[TW]Fox;23971176 said:Could you show me which part of the MOT test it would fail?
http://www.transportoffice.gov.uk/c...nualsandguides/mottestingmanualsandguides.htm
Class V, Windscreen;
Reasons for rejection:
A. The presence of an object which seriously restricts the driver's view of the road ahead, bearing in mind the original design of the vehicle
B. any crack, surface damage or iscolouration which seriously restricts the driver's view of the road to the front or side
It would depend on the tester, but I suspect most would fail it as I think the guidelines are or at least were 40mm outwith zone A.
And for those saying it cannot be fixed You are wrong. The moisture is sucked out of the cracks & impact point & then it's filled with a very strong resin. The cracks would be barely visible after & the impact point would just be a small blemish in the screen.
And before you say it, The Insurance companys are quite happy with these repairs & pay for them under your screen cover.
[TW]Fox;23971224 said:How can it possibly seriously restrict the drivers view of the road?!
It's on the black opaque section of the screen!
It clearly stretches out beyond the edging!
I would fail it under class5 section 6.9 - reasonsfor failure numbers 2 & 3
