I usually shave 3-4 times a week and change blades after about a month. Never get any rash or irritation even though its obvious the blades are not as sharp at the end as the shave is just not quite as close.
A month? What the!
Are you 15?
Same. Blade doesn't feel as nice after the first 4-5 shaves, but it still does the job. I find it works out a LOT cheaper to get some nice shaving gel and moisturiser instead of changing blades every few days.I usually shave 3-4 times a week and change blades after about a month. Never get any rash or irritation even though its obvious the blades are not as sharp at the end as the shave is just not quite as close.
My Fusion Pro blades last 2-3 months each timeWhat long lasting, sharp blades would you recommend then!?
