Gillete fusion blades - how long?
I usually shave 3-4 times a week and change blades after about a month. Never get any rash or irritation even though its obvious the blades are not as sharp at the end as the shave is just not quite as close.
I shave on sundays and ive never changed a blade becuase i usually lose the razor before that happens :p
perhaps if the OP shaves everyday his hair is both thicker and the blade used everyday so it may wear a lot quicker
A month? What the!
Are you 15?
A month? What the!
Are you 15?
36 next month with actually a fairly tough but not overly thick beard. In an ideal world for work I should shave every day to be completely presentable but luckily in my job its not an issue but anything over 2 days and its very noticeable and I feel scruffy.
Same. Blade doesn't feel as nice after the first 4-5 shaves, but it still does the job. I find it works out a LOT cheaper to get some nice shaving gel and moisturiser instead of changing blades every few days.
Shave once a week and change my blade once a month.
I'm using a gillette blade of some kind and neve had a problem,I tend to buy what ever is in offer at the time,don't stick to one brand.
3 shaves, no more no less.
Changed to mach 3's to see if I can get more than 3 (one down a few more to go), got a better shave out of the mach 3 too!
Not ready to learn to learn to shave properly and manly yet...
One or maybe two shaves each.
I get horrible rash irrespective of how much care, caution, temperature control, moisture application and variance and whatever else I've tried in the 11 years I've shaved.
I hate shaving so much :(
I shave once a blue moon, I don't care about the appearance, i find that people don't seem to mind these days.
When i do i go to town with the real close clippers, then an electric shaver and then the glorious wet shave. :) My Fusion Pro blades last 2-3 months each time
I think its the blue strip they use, its kinda slimy which helps it feel smooth while shaving but soon as its gone which is probably 2-3 times the underneath white strip is rough and drags. I think they're designed like that solely to keep people changing blades well before the blades are actually done with.
I've changed to using a cheap hair trimmer as my beard trimmer. I just use it without the protective bit on. Have used this method for the last 6 years.
Now most razors burn if I do decide to shave. Found that the King of Shaves are a nice one to use. Cheap and pain-free.
I use the Fusion Power blades (The vibrating ones), normally get about a month out of them, but my work requires me to be clean shaven so the blades only have to take off minor bits of stubble, not full blown face-fungus.
