Do I see 32C on the climate control?![]()
Probably owned by an idiot who doesn't know how to use climate control judging by the manual air flow selection and A/C off.
[TW]Fox;23970481 said:Or it's had a totally flat and/or disconnected battery in the recent past..
Surely it defaults to Auto at a sensible temperature, mine sure does.
Seems bizarre, sure mine goes to 21. I question why the 32c option is even there, why would anyone want their cabin so hot![]()
Never used to before but recently there have been nights when I've been out for a drive and the air outside hasn't been chillingly cold but just cool enough to feel it with the windows open around the winding hilltop roads here. Drive too long like that at 21 degrees on the CC though and it gets a bit chilly all over so I set it to floor vents only and on 32. Very comfortable mix of air![]()
I buckled and ended up adding the adaptive suspension, for £500 it seemed like good value and the reviews i have read suggest its well worth it. Im also a sucker for gadgets
330CD up for sale, overpriced but in no rush to sell for the momentId say £7750 is more realistic
http://www.pistonheads.com/classifi...46-330cd-m-sport-2005--w-bmw-warranty/1185957
Dealer thinks delivery should be made first few weeks of May.
£250 ish?
£250 ish?
I paid £289 from our local 'indy' in Birmingham for an Inspection II and new thermostat
I paid £200 for new front discs and pads at a friends garage, good luck getting it all for less than £400
I'd have a guess at your discs and pads being £100 parts alone, plus markup. Labour at what, an hour say £60. Probably £200 plus the VAT for that alone.
Thanks all, very helpful, I have 2 local indy's that I'm visiting over the next few days, will let you know how I get on.
