A 7970 ghz edition would probably be a 80-90% improvement on the latest drivers over your 480.
Ya and when you factor in overclocking to say 1200/1700 or something similar it's likely to be double performance.
Don't bother with the ghz edition, just overclock the card yourself.
Aren't the GHZ models higher binned chips with the potential to overclock further than the normal 7970s? I know this isn't always the case but...
Nah they're just booted out with 1.25V to rule out any possibility of them falling over at the clock speeds they're set to.
i may sound like a noob but what is the ghz edition ?
does overclocking the gpu make a noticable difference ?
1ghz core clock (or more) plus faster memory speeds too.
is it worth the extra price ?
A waste of time unless the person doesn't want to do it themselves.
Yes, massively when you consider the headroom the 7900 series has.
No, not unless you're benchmarking heavily, and even then I probably still wouldn't bother.
its probably another marketing trick ?![]()
im considering buying a 7950 for my new build, will it void the warranty?
