Logitech Blitz ** ONLY 100 OF EACH AVAILABLE AT THESE PRICES **
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys.
Doing some deals on Logitech products for you. First 100 pcs of each.
First come first served!
Logitech G300 Gaming Mouse (910-002489) @ £21.98 inc VAT
The Logitech® Gaming Mouse G300 gives you more power, more control and more loot. Nine programmable controls let you move keyboard commands to buttons that are in easy reach. Onboard memory allows you to store up to three game or player profiles on the mouse. You can move it between computers without having to reconfigure it every time you do.
- Ambidextrous Design
- Corded
- Custom-Color LEDs
- Ergonomic
- Forward/Back Buttons
- Full-Speed USB
- Gaming
- High-Definition Optical Sensor
- Optical Sensor
- Programmable Buttons
- USB connection
Was £26.99 Inc. VAT
Only £21.98 inc VAT.
ORDER NOW
Logitech G400 3600DPI Gaming Mouse (910-002279) @ £22.99 inc VAT
Set your sights on victory. With a high-precision optical engine, the G400 gives you consistent tracking and precise aiming no matter how fast you move your hand.
Instant access to four dpi levels lets you shift from pixel-precise targeting to lightning-fast maneuvers. A sculpted comfort grip, low-friction feet and eight programmable buttons keep you comfortable and in command.
You've got the upper hand with precision targeting and pinpoint accuracy. Your mouse communicates over USB at a blazing-fast 1000 reports per second - as fast as USB can go, and eight times faster than standard USB mice.
- Weight: 133 g
- Connectivity Technology: USB
- Movement Detection Technology: Optical
- Buttons Qty: 8
- Movement Resolution: 3600 dpi
- Performance: 1 ms response time, 5.8 megapixels per second, realtime sensitivity switching 400 - 3600 dpi, 25 G maximum acceleration
- Features: Programmable buttons, sensitivity adjustment, polytetrafluoroethylene (PTFE) feet
- Cables Included: 1 x USB cable - integrated
- 3 years warranty
Was £27.99 Inc. VAT
Only £22.99 inc VAT.
ORDER NOW
Logitech G500 5700DPI Gaming Mouse (910-001262) @ £32.99 inc VAT
The Logitech Gaming Mouse G500. Your weapon of choice for precision and control. Gaming-grade laser gives you game-changing precision at any hand speed. Onboard memory lets you save and take your settings for your favourite title with you. Weight tuning gives you up to 27 grams of extra weight for personalised feel and control. Dual-mode scroll wheel with hyper-fast scrolling provides click-to-click scrolling that's perfect for weapon selection. On-the-fly adjustable dpi gives you the right level of precision, from pixel-precise targeting (200 dpi) to lightning-fast manoeuvres (up to 5700 dpi), for whatever game you're playing. And ten programmable buttons put valuable macros in your hand.
- Gaming-grade laser gives you game-changing precision at any hand speed.
- Onboard memory lets you save and take your settings for your favourite title with you. No software required.
- Weight tuning gives you up to 27 grams of extra weight for personalised feel and control.
- Dual-mode scroll wheel with hyper-fast scrolling provides click-to-click scrolling that's perfect for weapon selection when you're gaming. Or switch to frictionless hyper-fast scrolling to fly through long Web pages when the boss is looking
- On-the-fly adjustable dpi up to 5700
- Ten programmable buttons put valuable macros in your hand
Was £39.99 Inc. VAT
Only £32.99 inc VAT.
ORDER NOW
Logitech G700 Wireless Gaming Mouse (910-001759) @ £52.99 inc VAT
The Logitech® Wireless Gaming Mouse G700 keeps you comfortable, in control and deep into your game. Its 13 programmable G-Keys can be used to perform single actions or complex macros with a single click. The natural curves fit your hand for epic levels of comfort, so you can keep at it for as long as you want. And its full-speed wireless connection gives you gaming-grade performance coupled with wireless freedom. It comes with a quick-connect cable that charges your mouse and can transmit data over the cable. When your guild gets together, you'll have all the control you need to do battle, complete quests and level up your character. Logitech® SetPoint™ software required for initial setup and is available at logitech.com/downloads.
- 13 individually sculpted, programmable G-Keys let you perform either single actions or intricate macros with multiple keystrokes, mouse events, user-defined keys and repeating. No matter what your game, you'll get deep into it. You have the control you need to play better. To conquer more. To win.
- With natural curves that fit your hand, you get epic levels of comfort, while smooth-gliding feet let you manoeuvre effortlessly. You'll play comfortably, without distraction, for as long as you want.
- Full-speed wireless (1,000 reports per second) helps eliminate lag so you enjoy gaming-grade responsiveness and wireless freedom. You get a steady, powerful connection with no dropouts.
- A quick-connect cable for recharging and data transfer lets you plug in fast and continue your campaign without pause. You'll never run out of power. And you'll always have a backup for reliable connectivity.
- You get a mouse that's crafted just for gaming. The gaming-grade laser gives you game-changing precision at any hand speed. Onboard memory lets you store up to five profiles*. And the dual-mode scroll wheel can switch from click-to-click for weapon selection to free spinning for hyper-fast scrolling.
Was £62.99 Inc. VAT
Only £52.99 inc VAT.
ORDER NOW
Logitech G510 Gaming Keyboard (920-002762) @ £59.99 inc VAT
Get instant access to the tools and intelligence you need to win. The Logitech® Gaming Keyboard G510 delivers the features you're looking for when losing is not an option. Get real-time game stats and PC performance data with the GamePanel LCD. Keep keyboard controls in plain sight day or night, with custom-colour backlighting. Integrated USB audio provides 3.5 mm jacks for speakers, headphones and microphone. And 18 programmable G-keys with three mode states each allow up to 54 pre-set macro combinations, or you can create new ones on the fly. Requires software installation.
- GamePanel LCD provides in-game stats, VoIP data, media information, system performance and more information without interrupting gameplay.
- The customisable backlighting can be configured to display a wide array of colours, including white, for playing in low light or the dark.
- Integrated USB audio lets you use your own headset with convenience and high-quality digital sound, and independently control game audio output and headset microphones.
- 18 programmable G-keys give you up to 54 possible macro combinations per game. Perform either single keystrokes or intricate macros with multiple keystrokes, mouse events, user-defined delays and repeating*.
- 500 Hz report rate boosts USB connection performance, delivering speeds four times faster than standard USB keyboards.
Was £82.99 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
Oh poo :( just when I bought my new keyboard! That G510 would have suited my needs so much better than my Sidewinder X4 (not that it isn't a fantastic keyboard, mind you). Though my G500 is acting up after many years of service, so it might be time to get a new mouse.
we have a gigantic 14 day returns policy banner at the head of our website.
it kind of gives the game away :p
It does! But further advertising 'give it a try and return one' must have a greater effect :P Don't get me wrong it's cracking CS and thats why i shop here, but what happens to all the unboxed products you get back? Clearance or back to manufacturer for re-boxing?
+1 on the Logitech G700 loving mine since I brought it a few weeks ago and logitech software is a joy to work with generally. Certainly better than my Razer and Roccat experiences so far.
I also use a G510 and G13 :-)
Pretty sure they then become B-Grade
