I downloaded 341.22 from uk.geforce.com and its the same installer and drivers installed same way as before, no reboot needed.
(although it does need a reboot for Afterburner O/C to work)
i discovered that you don't need to reboot you're PC for afterbuner o/c to work. you only need to close afterburner down completely so that it not even running in the background, then restarted it and it will display the new forceware version and o/c will also be applied.
Just been playing Bioshock Infinite for the last 4 hours. Sweet game and smooth as silk. No slow downs at all and averaging 84fps with everything maxed @ 5760x1080 - 1852MB max VRAM used.
Not very demanding and newer games are tougher on the GPU with lesser prettiness (is that a word)![]()
Have you? Says you have been offline for 5 days on Steam![]()
I too have the stutter bug / micro stutter again with these new drivers in BF3. 60FPS (VSynced) and it's not smooth at all. reverted back to the "old" beta's and all is well again. Bioshock tho runs like crap with the betas.. Waiting on new branch.
Anyone had a problem with bluescreening coming out of games on these?
I didnt notice the problem with my computer before but I twigged that its been happening since I put these on, game will run fine for hours then bosh, out you go, blue screen of death.
