If anyone with a GTX670 could test this in multiplayer and let me know.
Also, could it even stretch to 4xMSAA?
Thanks!
Specs below but looking to upgrade as GTX560 isn't cutting it.
[email protected]
8GB RAM
Win7 64-bit
Right to everyone calling me a liar read this then say sorry.
Here is a benchmark of a STOCK 670 BF3 multiplayer
62fps minimum on STOCK
http://www.hardocp.com/article/2013...ver_performance_summary_review/5#.UVMvhVceE0w
62 minimum on stock![]()
If your seeing no cpu usage something must be wrong.
Even with my 3570k @ 4.8ghz it still uses 70% cpu.
Do you think the GTX650Ti Boost in SLI would hit 60FPS+ minimum FPS in multiplayer maxed out?now in SLI 670 i see a consistent 100+FPS and don't really drop at all.
Thanks, it's just I saw a person with SLI'ed GTX660's and he was getting dips to as low as 28FPS in multiplayer.
The majority of the time it was at 60FPS, but not sure if that's microstutter as it did jerk for a second everytime it dipped. -.-
sounds more like the SLI microstutter issue rather than a problem with the card
That's a 670 which is a fair amount better than a 660ti, also I don't believe the reviewers play for long enough or get into enough intense action to see these dips on 64 player multiplayer. You must have some super edition 660ti because my 680 even on the newest drivers dips below 60 at times with a [email protected].
On modern games there really isn't a lot of difference between a 660ti and a 670.
Crysis 3 for example it's just 2 frames.
The 670 in that bench is only running at 980mhz core 6000mhz memory.
My 660TI on unlocked bios was running 1293mhz core 7100mhz memory.
Again I got no reason to lie about my 660ti never dropping below 60fps, I don't even own one any more I switched over to 7950.
If your 680 is dipping below 60fps it's probably your cpu/ram.
Yeah buddy it's my parts, even though multiple people have told you their FPS drops below 60 on better hardware than yours. Lets all go out and buy 660ti's lads they're far superior obviously![]()
Funny how '660ti' has now changed to 'heavily modified BIOS overclocked 660ti running 1293Mhz core and 7100Mhz memory'
980mhz on the 670, wonder what model it was and if that was it's boost clock speed at stock. Stock core speeds for the 670's range from 915-1058mhz, this however doesnt include the boost clock. The gigabyte wf has a stock core of 980mhz, mine boosts out of the box to 1189mhz but ive oc'd on top of that. Memory wise, 2000mhz is about average for the range as again the speed go's up/down from that figure depending on vendor/model.The 670 in that bench is only running at 980mhz core 6000mhz memory.
