Hello GD,
I shaved my head today for the first time and decided to use my double edge/safety razor.
It took me about half and hour and multiple passes for me to get it fairly smooth.
To those of you who razor shave you head what do you use?
I remember seeing a little razor head on wheels a while back but can't find it now. I have also considered normal (e.g. gilette) multiple blade razors but they are not very good for face shaving so I assume the same for head.
Maybe I just need to practice with the safety razor. I have heard about shaving in the shower which I guess may be quicker due to having a constantly wet head.
Thanks in advance.
Thanks in advance.
Clogged up? Only if youve not shaved for a couple of weeks and the hair is long..and even then you just rinse the blade just as you have to do with a single blade razor.
