Hello Overclockers im looking to buy the "Titan 350i Gelata" Intel Core i7 3770K @ 4.40GHz Overclocked Ivybridge Quad Core Gaming PC
Any information/feedback would be well appreciated.
http://www.overclockers.co.uk/showproduct.php?prodid=FS-339-OE
What memory brand is used in this build?
I`m also going with the option for a gigabyte 7970..
http://www.overclockers.co.uk/showproduct.php?prodid=GX-097-GI&groupid=701&catid=56
Are up to date drivers installed on the build? or out the box disc (having WIN7 64bit OS installed with build as well)(same question on the BIOS?)
Im also after a monitor...ermmmm this one Asus VS278Q 1MS Gaming Widescreen LED Monitor - Black
http://www.overclockers.co.uk/showproduct.php?prodid=MO-046-AS&groupid=17&catid=1120
Is this a good monitor paired with the GFX card?
I gather from another thread that the liquid cooling is just a sealed unit cooler for the CPU? so i will never have to mess with it?
How hot does this system run, wont need any extra cooling? (really dont want any)
With these overclocked systems can you switch between OC`d and not OC`d? is it easy enough to do or a whole bunch of messing? a profile saved somewhere and can be just loaded unloaded?
The case for my build....BitFenix Raider Tower Case - Black
http://www.overclockers.co.uk/showproduct.php?prodid=CA-014-BX&tool=3
I have read reviews on this case and people warn that a long graphics card on some MB`s can be too long because they hit the corner of a noddle like thing on the drive bays of the case?
So i guess the question is does the positioning of the hd 7970 on the MB have enough room so that it doesnt touch the drive bays...i see a section of the drivebay comes out to fit long cards?...but from reviews people say the GFX card can hit the bays even with the section removed on some set-ups???
Thanks in advance to anyone who can help me out here with the machine of my dreams!!!!.
