Pretty good mate, have you had the 920 since release? Iirc i got mine a few months after release, it was a further 6 months before i tentatively tried clocking it. Dont know why i was so worried, probably the easiest chip ive ever had to clock. Gotta get round to reapplying the oc on the 930. It's a cracking little chip, 4.3ghz with a slight bit of tweaking. It uses the first 6gb kit of high end ocz reaper that was originally in my 920 setup.Cheer's and how's you m8.![]()
Any modern gpu such as 670/80, 7950/70 and your good to go.
Bf3 will run extremely well, got a 670 wf here with a pretty meaty oc on it. Maxed bf3 out and it ran great in the 920 setup at 4.2ghz.Yeah, I was thinking a 660 or 670 at the end of April. I prefer Nvidia.
BF3 will be amazing then I bet!
Such a shame they stopped making ram. The reaper kits were outstanding, tbh theyve shown that theyre not very good at making ssd's, so perhaps they should have stuck to something they were good at.
Have an i7 930 in my second pc. Spec in sig was a replacement for an i7 920, bit of a silly sidegrade tbh.
Yep, and tbh mate it was a very silly move. The 3570k does clock higher, temps are pretty much the same. But performance in bf3 has dropped a tiny amount. The main benefit of the 3570k is much lower power usage, and as i was running two clocked x58 setups, one had to go to cut down on electricity usage. Not massive drops im sure, but every little helps. I will be changing the 3570k though to a 3770k soon.I think I remember you upgrading to see if you could get anything else out if your gfx on BF3.
