Caporegime
- 18 Sep 2009
- Dormanstown.
I run 3 120Hz screens without issue. It worked straight out of the box with no messing about needed. If you use 3 3D screens on 1 card, you need to connect 2 D-DVI connectors and 1 DP connector.
Agh yeah, I completely forgot you've got a 3 x 120HZ set up
I remember when the SA23700D was on that cheap deal, tons of people bought some (And some people bought 3, and were having an absolute nightmare trying to get them all working as they should)
I bought one, had a GTX680 at the time, had to get rid of the GTX680 for the 7970 though.
Sorry. I find it frustrating how many times AMD has made big headlines and nothing has come of it and instead of their customers holding them to it they seem to quickly forget it and fall hook line and sinker for the next big splash. Anyhow thats my stance I'll refrain from further derailing the thread.
To give an example ; Bullet. All that noise, and then NOTHING.
Sure they made some noises about tablets, and what have they got right now? Z-60, which is just pretty much a more efficient C-50, which is currently in a Fujitsu tablet at nearing the same price as i3's/i5 tablets.
Sure, they've got Temash/Kaveri, etc, but they're not out yet.
