With GameFly, do you have to use the GameFly Download Client if the game activates on Steam?
It said to install the client, but the keys come in your email invoice-if it's Steam titles.
I have bought a few Steam games on gamefly and have never had to install their client, just pop the key straight into steam.
No - you dont have to use their client if you dont want to. You will receive the game keys by email where you can then just redeem on steam.
Be careful though sometimes it not obvious so check the game out that mentions steam before just assuming it.
In case of Spec ops and Darkness2 both where straight forward keys which i received in seconds.
Yay, my GameFly order is "Under Review" even though I've ordered from them countless times before using the exact same details without issue.![]()
No problems here, confirmation straight away and serials available in the purchase history section under the order number. Two thumbs up.
Bioshock 1 + 2 are Windows Live titles and require online activation once installed with the key you get from Gamefly.
Orcs must die 2 for 3.7 euros! I tried to buy it, only to find that i already own it LOL!!!!
Tropico 4 Collectors Bundle 75% off - £7.49 activates with steam
http://www.greenmangaming.com/s/gb/en/pc/games/strategy/tropico-4-collectors-bundle/
EDIT - £6 when you use code GMG20-FDSCL-AQQXD
That's when you know it's time to stop buying games![]()
Found out the hard way
Bioshock 1 and 2 don't activate on steam if you buy them from GameFly...oh well, only £2.39
