- 2 Aug 2010
- Egypt/ Surrey
I am hoping to over the next few weeks transform my TJ07 build into something a bit more special. I am not much of an overclocker or a modder but I will have a go.
A little teaser:
As it stands 5/4/13:
The components and peripheralsI have:
A TJ07 case (big hole in motherboard edition)
1 7970
I5 2500k @ 4.2ghz
2 SSDs 1x 512GB and 1x 128GB
1tb Sammy F3
MSI P67-GD65 motherboard
16GB XMS3 (4x4gb)
Xonar DG sound card & Sennheiser PC350 Headphones
Corsair HX650 power supply
RAT 7
As it stands 25/ 3/13:
Watercooling:
EK PSC compressions
Supreme HF CPU waterblock
7970 EK plexi waterblock & backplate
EX 480 radiator (I think)
6x gentle typhoons 1450rpm
Mayhems Raspberry Purple (previous colour)
Mayhems X1 UV Blue x2 litres
3metres of tubing
D5 pump with top
EK150 tube reservoir
Cable management? I really need to sort this out.
Here's a list of thoughts for the next steps
Ideas:order and install Coldzero motherboard tray, midplate, backplate and PSU plate!
Sort out cable management
Better overclock (currently using genie button @4.2, temps are good though)
Crossfire 7970s?
Get a higher resolution monitor?
Better keyboard?
Larger res?
Bay res?
Braid all cables with MDPC-X. Colour/s?
Get a Dremel and rivet gun.
A Shoggy Sandwich to dampen the vibration
Cut gap in rear of tray for cable routing above PSU onto rear of tray.
Cut a gap in the USB3 plate to allow tubing?
Insert a drain point into the loop, underneath?
Create a better mount for the pump.
Add a 240 to top?
A little teaser:
1 7970
I5 2500k @ 4.2ghz
1tb Sammy F3
16GB XMS3 (4x4gb)
RAT 7
Watercooling:
EK PSC compressions
3metres of tubing
D5 pump with top
Ideas:
Crossfire 7970s?
Better keyboard?
Bay res?
Add a 240 to top?
