Help me stop the obscenities.
My life is one big mad moment :p
:D
Lookin' good :D
This board is £3 more. It is a full ATX rather than a M-ATX which is nice since the case is a full ATX, it is a more attractive looking board with a matte black PCB which is nice, and best of all - it is in stock :D
http://www.overclockers.co.uk/showproduct.php?prodid=MB-426-GI&groupid=701&catid=1903&subcat=2399
This case is the same price for something that looks a little different and in my opinion nicer. Personal taste really :)
http://www.overclockers.co.uk/showproduct.php?prodid=CA-010-BX&groupid=2362&catid=2277
The 7K1000.D as you yourself mentioned - fastest HDD out there, and with a full 2 year warranty instead of the measly 90 day B Grade warranty :)
http://www.overclockers.co.uk/showproduct.php?prodid=HD-024-TS&groupid=701&catid=14&subcat=1279
Just one question..... how do I post Your Basket.
I won't tell you what my son called me. ;)
And I thought I was up to speed when using forums. ;)
You can post the basket using a plugin for Chrome called "OcUK Shopping Cart Viewer"
With the plugin installed, a clipboard icon will appear near the top right corner of the window, click it and then paste the code which is then copied - where you want it :)
Like so:
YOUR BASKET
1 x AMD A10-5800K Black Edition 3.80GHz (Socket FM2) APU Trinity Quad Core Processor (AD580KWOHJBOX) £99.95
1 x Microsoft Windows 8 64-Bit DVD - OEM (WN7-00403) £79.99
1 x Gigabyte F2A85X-D3H AMD A85X Chipset (Socket FM2) DDR3 ATX Motherboard £64.99
1 x Toshiba (7K1000.D) 1TB SATA 6GB/s 32MB Cache - OEM (DT01ACA100) HDD £51.95
1 x TeamGroup Xtreem LV 8GB (2x4GB) DDR3 PC3-17000C11 2133MHz Dual Channel Kit (TXD38G2133HC11DC01) £49.99
1 x Corsair Builder Series CX 430W V2 '80 Plus Bronze' Power Supply (CP-9020046-UK) £40.99
1 x Xigmatek Asgard Pro Gaming Case - Black £32.99
1 x OcUK 24x DVD±RW SATA ReWriter (Black) - OEM £16.99
Total : £451.94 (includes shipping : £11.75).
Lookin' good :D
Only specced the mATX version to save money, but you right, the ATX does look better
Asgard is better and comes with 2xfans installed
The "B" hdd I specced comes with the 90 day OCUK warranty, plus whatever is left of Seagates 2 year warranty.
Also the Asgard comes with 2 fans.
Fair enough with the comment on the case :) As I said, just personal opinion :p
And the 7K1000.D is mainly just cos its quicker as there is no SSD in the spec :)
Ammended my post :)
Ammended my post :)
Also forgot the Asgard also has USB 3.0x1. But I suppose it depends on what the lad chooses, if his dad gives him a choice. :D
If the lad chose something himself I bet it would be from the purple people ;)
Building a pc is so like whatever :p
