Consoles run at 30fps so there is no point in playing a game of a 120Hz monitor (120fps+)no
but it is a fast moving game, not to bothered about 3D
I do use it with BF3 on the PC though. so I wouldn't notice any smoother play on this monitor even with fifa on xbox 360
I had an xbox running through mine, looked no different whatsoever. Consoles atm cant utilize 120hz, maybe the next gen will? I doubt it tho. You WILL see a big improvement on your pc gaming however
EDIT: after some searching, 120Hz is utterly pointless for console due to the low FPS, and unless your PC can handle well over 60fps you won't see a change.
Apologies for hijacking the thread again....
The BenQ XL2411T monitor came at 11am this morning. Fantastic service from Overclockers!. DPD delivered Sat with a 3pm order Friday...
If you decide to get this monitor going from an old 19" like I did, you wont regret it. Great build quality, stand is excellent, feels like quality!
I cant believe the difference, the blacks are so much better. I didnt realise I was looking at such horrible colours before. This monitor has changed my gaming experience completely!
Driver loaded into Windows 7 first time, reboot. Set reslolution and 120Hz. 5 mins to set colours using websearch!
Very impressed!...thanks to all who recommended!....
