***Images of things purchased in April 2013***
All from some power seller on eBay for 99p with free postage.. :D
iPhone 4 flip case
Cleaning cloth
Screen protector
Stylus
and USB cable
Only problem I found with the case is it has no hole on the bottom for the cable. Which means you have to have the flap open when connected to computer or charging up.
Finally was it two years ago it was on c4, hopefully it's Very tasty.
Should be able to finally finish of my serving spoon, double edge hook knife. When you cut a deep bowl, seems you need blades on easier side or two knifes, to carve the wood.
A while back I picked up a Crucial V4 on pre-order offer, to try Windows 8, and to say that it wasn't very good, is something of an understatement.
I've given up cursing it and waiting for HDD activity to drop below 100% for more than a few seconds, and got one of these instead;
http://i.imgur.com/ySt2G87.jpg[IMG]
the immediate improvement is staggering, turns out Windows 8 is actually pretty nippy, who'd of thought it.....[/QUOTE]
I've actually been nothing but impressed by W8, I haven't really understood the hate for it. Takes a bit of getting used to and changing of certain habits, but all round it's an excellent OS imo. Glad you've changed your mind on it! :)
Cheers pal! I test drove about 6 other cars and this was by far the nicest to drive (for me anyway). Each to their own and all that!
I have an astra and get similar comments don't worry.. Its big and fits everything i want in and it goes from A-B not burning too much fuel
