I know what you mean about some of the users having unrealistic expectations.
Have you got yours yet? I am like a child I really am so excited, I just can't get over how ridiculously, monstrously quick it is. The test drive was hilarious, even the salesman was laughing at how stupidly rapid it was!
Running in to a 4k limit? Right, so the upper part of the rev range isn't run in at all for x mileage then you boot it all of a sudden?
Yea, my ep3 has done 107k miles and is on the original clutch/gearbox/engine, pretty much everything... but that's irrelevant.
3k miles in a car is effectively nothing.
dont shoot the messenger
I doubt anyone will keep it under 4k for the duration of the run in, merely stating there is plenty fun to be had sub 4k if you decide to follow BMW running in procedure
Oh I'm not, it's just something I see said very often yet every technical article by anyone that knows anything about building engines
[TW]Fox;24076392 said:So do you suggest then that the designer and manufacturer of the engine does not, therefore, know anything about building engines?
All I said is that every technical article on it by anyone who knows anything about engines suggest that it should engines should be run in as hard as possible.
How does the E90 320D sport compare to the E46 320D sport. Are you saying the E90 would be slighly quicker? Would it have better fuel economy with it being a newer engine?
[TW]Fox;24078246 said:Many of them don't have a newer engine, the M47 was carried over from the E46 for about half of the E90's production life.
