New BMW's not like what they once were?
I know what you mean about some of the users having unrealistic expectations.
Have you got yours yet? I am like a child I really am so excited, I just can't get over how ridiculously, monstrously quick it is. The test drive was hilarious, even the salesman was laughing at how stupidly rapid it was! :cool:
had my Estoril Blue 3dr manual since last November, you've mentioned annoying Porsche and RS3 drivers, I'll give it 3 months before you say bye bye to your licence :)
Also, even keeping it to the running in 4k limit, you will still be extracting the majority of its performance.
Running in to a 4k limit? Right, so the upper part of the rev range isn't run in at all for x mileage then you boot it all of a sudden?
dont shoot the messenger :)
I doubt anyone will keep it under 4k for the duration of the run in, merely stating there is plenty fun to be had sub 4k if you decide to follow BMW running in procedure
Yea, my ep3 has done 107k miles and is on the original clutch/gearbox/engine, pretty much everything... but that's irrelevant. :)
3k miles in a car is effectively nothing.
I concur completely irrelevant, we are talking about the M135i box, as an owner I can offer my experience albeit 3k miles worth, but as its a newish model [available since last October] I don't think there are many examples of it with upwards of even 10k miles, do you ?
Anyways I see your bid of 107k and raise it with my UKDM Prelude VTEC with 125k on original gearbox/clutch :)
Oh I'm not, it's just something I see said very often yet every technical article by anyone that knows anything about building engines says that a new engine should be run in as hard as possible as this is the time when the piston rings seal to the bore. Of course by the time the car is delivered from the factory it will have some miles on it.
Running in to me is allowing the new brakes, clutch, gearbox etc time to bed in before hammering it.
So do you suggest then that the designer and manufacturer of the engine does not, therefore, know anything about building engines?
I see.
But the running in proceedure which suggests not taking it over 4k rpm is written by the people who designed the engine.
Circles, going round.
All I said is that every technical article on it by anyone who knows anything about engines suggest that it should engines should be run in as hard as possible.
Whether BMW state the 4k limit to protect other parts of the car, such as the gearbox, clutch or whatever, I don't know.
*maybe not every article but most that I've seen.
Good cylinder fill and not constant load helps bed the rings.... Like you are trying to say. But if you have identified the cylinder to ring interface is still bedding in why would you rape those high spots by overspreaeding the engine and glazing sections of the piston ring you were just championing to get seated against the piston nicely?
The generic, 'hard' running of an engine is amusing. Lets be hard on cam bearing surfaces... Lets let the car idle from repeated cold starts...
I often see BS on forums, your vitriol here is yet more ;)
After owning a few BMW's over the years, I can honestly say the build quality of my current E90 isnt as good as past models, particularly the interior quality.
That said the E90 doesnt suffer from the rust issues that are common on the E46, and an equivalent model is quicker and handles slightly better IMO.
Next car will be an F30, so hopefully the quality will be a step up
How does the E90 320D sport compare to the E46 320D sport. Are you saying the E90 would be slighly quicker? Would it have better fuel economy with it being a newer engine?
Many of them don't have a newer engine, the M47 was carried over from the E46 for about half of the E90's production life.
Fox is correct, the earlier E90 320d has the M47 engine and similar fuel consumption as the E46. The E90 with the same engine is still a little quicker though, half a second to 60 on paper, and handles a little better.
Cheers
I absolutely adore the E46 M3's, love the E36 M3's and would probably sell a kidney for the E30 M3's. But after that point BMW somewhat lost their direction in my opinion. The 3 series after that point do little to excite me.
