ya that worked , thanks, why does Samsung not optimize it properly, this is supposed to be a high end device,
hope its not the same on the s4
It probably will be! Nova will be the first app I install when mine arrives
It probably will be! Nova will be the first app I install when mine arrives![]()
but why would this be ? cant believe such a high end device and this happens, can they not optimize it so works well ?
There's nothing wrong with the TouchWiz launcher really?![]()
Nothing wrong per se, just that there are better and more user friendly options. personally, I like better options.There's nothing wrong with the TouchWiz launcher really?![]()
its not just that, things like touchwiz and sense innovate for the sake of it which often ends up with you having a bunch of stuff going on you don't even want, something like Nova sorts that out.
I even used Nova on my nexus devices tbh.
I'll be getting one of these as soon as my contract is up =D Although i agree maybe the screen is getting too big.
Hi, i been searching for the cheapest sim free , i have a sim only from t mobile , £16 a month , unlimited calls, texts and data, 12 months , which i think is a great deal
I have a s3 now, but looking to buy the s4 on release day, most places are £579.99 ,
i found this site , anyone used this site before ?
http://www.unlocked-mobiles.com/sim-free-mobile-phones/samsung-galaxy-s4-sim-free-p-84354.html
its £535.97 inc delivery so much better deal then others
I've pre-ordered my S4 from them but have never used them before. I have asked in here a couple of times if anyone has used them before but nobody has so I'm just hoping for the best. Not sure why its so much cheaper and half expecting a delay email close to the release date but we'll just have to see how it goes.
Just had a play with a white S4 instore. I gotta say, I love it's construction. Makes you think how plasticy the S3 is! Even if its a small difference. No noticeable difference in size too but the screen is nicer.
What store did you try it in?
Anyone pre-ordered with Samsung so they can be at the exclusive launch event?
