- 30 May 2012
- Bristol
3820 gives you more PCI-E lanes, quad channel RAM, an upgrade path and a soldered IHS which pretty much guarantees higher clocks (although that's negated by the IPC being slightly slower). It's also cheaper than a 3770k.
Not all of those will be true of 4770k vs 4820k, particularly the upgrade path.
In fact the upgrade paths will swap around, with the 4770k most likely having an upgrade path to Broadwell on the 1150 socket, whereas the 2011 socket will most likely be dead after IB-E.
