Fast USB 3.0 Flash Drive - Much Slower on USB 2
nb-
nb-
13 Jan 2007
I am looking for a fast USB flash drive. The SanDisk Cruzer Extreme USB 3.0 gets a lot of recommendations, but I have also seen comments saying its very slow on USB 2.0, with transfer speeds a long way short of saturating the USB 2 connection. As it will be used quite a lot on USB 2 this could be an issue.
Has anyone here got experience of transfer speeds on USB 2, is this really a problem?
Write speeds may be a little slower, (horrible is the wrong word) but in real world performance, you're not going to notice much difference. What I love about the Corsair Survivor is it's build quality. It's a very nice device to use and extremely resilient to any accidents you might have with it. My last drive was a plastic Kingston and it was pants.
40MB/s compared to 190MB/s is horrible so yes I used the correct word.
They are not correct figures. For a comparison to my Corsair Survivor 32Gb, we'd be looking at 110Mb/s and not 190Mb/s. Which like I said, in real world performance, would only be noticeable on massive files. The few seconds you would actually save transferring small to medium files, which is what most of us do on a regular basis, is minimal and not an issue. So again, horrible is not the right word.
http://www.everythingusb.com/sandisk-extreme-usb-3.0-flash-drive-21622.html
All currently shipping Extreme USB 3.0 flash drives are rated by SanDisk as having 190MB/s read speeds. To put that number in perspective, that's about 600% faster than the speediest USB 2.0 flash drives we've set hands on in the past, which speaks volumes for why you should upgrade to USB 3.0 if you haven't already. If you're lucky enough to have a USB host controller that allows for supersized BOT transfers (aka Turbo Mode or XFast USB), you can boost the read speeds even higher as my benchmarks will show.
Write speeds on the Extreme flash drives varies by model. For the 64GB and 32GB versions, this is 170MB/s and 110MB/s respectively, while the smallest 16GB model is only rated for 55MB/s.
Thank you for your input people. Sandisk I think it is since it looks smaller, fast and more convenient.
This is to replace my current buffalo 4GB USB stick that lives on my key ring which has gone wrong, most bizarrely, all that happens when I plug it in is it says the USB devices has malfunctioned, and it gets hot!
