Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
Im after one of those fancy buckets with the grit guard, and some new rags to clean the M135i when it arrives, im going to have to say good bye to my polish friends![]()
Sam
My Autoglym shampoo has ran out (2 years!), i am going to get some Megs Gold Class next, I hear those are good.
In terms of grit guard. Go to your local DIY store and get 2 nice and big buckets and then go on eBay/Amazon and search for Grit Guard, you can get ones with adjustable size. I think you will save money this way. You can go all posh and get those buckets that are on wheels, makes it easier to push it around as you wash the car
As for wax, I prefer longivity over that show room shine. Unless you clean your car every weekend, after a drive or two it is going to be dusty anyway. Collinite 476 or FK1000 are the 2 I would go for. You can use FK1000 on the alloys too. If you want to be quick then I like Spray wax, Autoglym Aqua wax is lovely, I have tried one of Megs' liquid wax but prefer Autoglym's more. The finish seemed nicer and it also smells nicer too!
As for best price, Halfords sometimes do 3 for 2 deals which isn't bad. But Cleanyourcar.co.uk's prices are ususally competitive.
You will need a lot of micro fibres though. Never have enough microfibres !
