Space Monkey
You’ve hit the dreaded Alien Respawn issue where it won’t respawn the OS back to a drive of different size.
Shrink your factory installed HD down to the same size as the SSD and then leave the empty space leaving you with a C partition same size as the SSD.
Respawn to removable media, install SSD and run the respawn, hopefully this tricks it; seem to remember others were having this issue. I installed a SSD but the respawn funnily enough worked for me.
But hopefully that works.
My M17x has a constant CPU fan, nothing too loud, the GPU fan however kicks up when under load and is quite audible.
Also, if you want to cut your loses and reinstall the O/S you can simply download a Windows 8 DVD as you’ve got the license key as that’ll be in the BIOS I think, or under the battery when you remove the battery is the COA number, the Asset Tag is in the BIOS so when you get the O/S back into the SSD you simply connect to Dell downloads and let the website search for all the drivers, it will use your service tag to find what is needed.
Saves waiting for Dell to ship a new DVD out, you’ve got a DVD write with your M17x.
