Spec me an SSD
13 Nov 2009
Hi all,
I'm looking for an SSD to go in a laptop (Thinkpad T61). Needs to be around the 256GB mark. Ideally no more that £150 ish.
What's the best I can get for the money? I've not really looked into SSDs since I got my Vertex 2 a couple of years ago. I'm sure things have moved on.
Have been looking at:
Samsung 250GB 840
Crucial M4 256GB
Any help would be great :)
its hard between those two as the m4 uses longer lasting multi level cell nand memory,the Samsung non pro uses triple level cell nand
but the Samsung should last a long time,and I trust their products plus its cheaper than the m4 but its upto you really,either drive is good
Thanks for the advice guys. I'll have to have a think about whether I can stretch my budget for the 840 pro. It looks great.
you wont see those read/write figures on your amd board though,so the cheaper non pro would be better imo unless your planning on upgrading the motherboard
Ah good point. Although this isn't for my main rig this is for a Lenovo Thinkpad T61 laptop. But I think the point still stands. It would be an old SATA 3gbps mobo.
So does that mean I won't get any additional benefit by going for the pro?
might be a bit faster iops but id doubt you'd notice,you'd see roughly 250-280mb per sec read/write no matter what sata3 drive you put in
intel sata3 ports would give you full rated speeds
Well that's saved me a few £. Thanks!
I suppose there is still the issue of the only 3 year warranty but I'm not sure the laptop has another 3 years left in it anyway. Certainly not as a primary workstation.
EDIT: 1,000th post! :D
Not sure if it's been mentioned above, but the T61 by default only supports SATA1 speeds (up to 150MB/sec).
There is a 3rd party BIOS available that enables SATA2 speeds (I have a T61 fitted with a M4 128GB drive and the SSD still makes a HUGE improvement).
