Not planning on overclocking.
Does the listed spec not need a graphics card to run StarCraft II at high FPS ?
Also, I think my mate would prefer an intel CPU.
Would an i3 paired to a 7750 do the job ?
enough for an i5 nd a 7850
Over budget a bit but way way more gaming power!
The card is great and that is my personal favourite cooler for the GPU. Since you are not overclocking, no need to a Z77 chipset or a K processor and the stock cooler will be perfectly fine.
YOUR BASKET
1 x Intel Core i5-3330 3.00GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £149.99
1 x **B Grade** Gigabyte ATI Radeon HD 7850 OC Windforce 2X 2048MB GDDR5 PCI-Express Graphics Card w/ Nexuiz, Sleeping Dogs & Dirt Showd (GX-100-GI) £129.95
1 x Gigabyte H77M-D3H Intel H77 (Socket 1155) DDR3 Micro ATX Motherboard £76.99
1 x Western Digital Caviar Blue 1TB SATA 6Gb/s 64MB Cache WD10EZEX - OEM ** Single Platter ** HDD £56.99
1 x Corsair Builder Series CX 430W V2 '80 Plus Bronze' Power Supply (CP-9020046-UK) £40.99
1 x Patriot Viper Xtreme 8GB (2x4GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (PXD38G1600LLK) £39.95
1 x BitFenix Merc Alpha Gaming Case - Black £32.99
Total : £541.94 (includes shipping : £11.75).
^boom
Thanks mate. The AMD CPU is now coming out more than intel.
Do you know which would perform better ?
Thanks mate. That last, i3 build, does look pretty good
