My build :)
Fans still wont work and now on load up its saying cpu fan error. and the fans are in red in the bios at 546rpm do i just click ignore?
1 x CPU Fan connector(s) (4 -pin)
1 x CPU OPT Fan connector(s) (4 -pin)
4 x Optional Fan connector(s) (4 -pin)
2 x Assistant Fan connector(s) (3 -pin)
You have enough fan connectors, just check they are correctly inserted.
If you are not going to be using both HDD bays I would remove one of them to help improve airflow.
Also look at moving the fans from off the HDD bays to behind the front dust filter unless you have already got fans installed there.
Just need to do some more wire tidying and take the plastic cover off the windowed sides as its all bubbly. :)
